same network on TP Link RE200
28 Aug 2011
Hi everyone hope you are all well.
Currently i have a TP Link RE200 extender , however i have WI FI blink cameras and can only connect them all to one network and one side of house has bad signal if i pick main router and vice versa if i pick extender.
Is there anyway to make the router the same network so each camera uses eother the extender or router depending on distance and what has better signal?
I am also having bother with the extender saying unable to get ip address and dont know how to fix it. I have had this extender for years.
Any help os appreciated
Thanks dean
Did you update the firmware for the extender?
whilst its a lower end one it still is part of the TPlinK mesh system so pared with a TPlink router it should be a breeze to get working.
I use TPlink stuff at home and whilst its not awesome by any level, it does the job.
I have an Ax73 router and a RE 305 i think it is. Ill be looking to adda couple more mesh points in the garden over summer.
