Hi
I've decided to update my monitor from a CRT to a LCD. I've done some reading and decided on a 20" WS. Looking at the Viewsonic 2035wm or Belina 102035. My main use is going to be office work(word, mail and internet) or gaming.
I'm aware these two TFts both use the same panel (MVA). I've noticed its not the most favored monitors on here although seems to do well in reviews.
I've narrowed my choice down based mainly on the panel, good color reproduction, good viewing angles and good contrast. Halfway house between IPS and TN.
Am I on the right track here ?
Is there another monitor I should checkout ?
TIA.
TIA.
If you've narrowed it down between the VX2035WM and 102035W then I'd suggest the Viewsonic might edge it slightly since it has more accurate colour reproduction out of the box, and so you might benefit from that unless you have a colorimeter tool.
