Ok posted a bit ago re wirless internet connection on my sons computer. Basically when launching either firefox latest edition or IE V7 a blank page comes up saying unable to locate DNS server . I have run ipconfig and can access the default gateway and ipconfig all shows the subnet mask checked that zero wireless config is started and it isnt (this seems to be a reoccuring issue each time the pc boots up zero wireless is not enabled) so started it again and launched the web browsers again but same thing just page saying that there is a problem and to check internet settings and make sure auto detect is on - which it is .. This is tiscali and all other pcs on the network can access sites.
I did a system restore but still have the same issue. I am at a loss as to what is causing this issue - could it be some kind of virus or trojan or would hijack help? Last time I resorted to doing a windows xp repair but to be honest I dont want to keep on having to do this. He has avast and firewall also ICP restrictions on ports into his pc .. Has Anyone got an idea of what I can try to resolve this issue.
I am sorry if this sounds a bit muddled but I hope you can decipher it.. Oh the O/S is Windows XP Pro OEM and has SP3 installed.
