Same Ram - Different Timings?
Permabanned
1 Mar 2007
Could use some advice before i break something :D
I have 2 x 1gb matched sticks of corsair ram in my pc at the moment with
5-5-5-12 timings and 1.9v
The other day i ordered another set but when it arrived it was slightly different although same make/brand/model etc but with timings of
5-5-5-18 1.9v
Before i noticed i installed it, cue successive beeps. So uninstalled it checked it over and noticed the difference. currently my ram timings are set to auto in the bios and wanted to know if i force my old ram to the new timings (i think the new ones are slower) will it work? if not and i try anyway will it damage anything?
timings hardly make a difference.....i would stick to looser timings and reliability
im not saying it would damage the memory but if it causes the odd crash here and there it just wouldnt be worth it.
Well, i managed to get it sorted this morning before i left, used manual timings and changed the voltage a little (0.025 iirc) hopefully it wont fall over any time soon :o
