Same screen for double monitors?
20 Aug 2010
I am thinking about getting a second monitor, I currently have a BenQ G2222HDL which is pretty nice. However, I am thinking of getting a slightly bigger one for the primary monitor and I am unsure if it would be a bad idea to get different size monitors for a dual screen set up.
I would be pleased if anyone has any advise.
It would annoy me if I had a bigger screen, because if you dragged something over, it would be bigger wouldn't it?
I have two Benq G2222HDL s now and they work brilliantly.
I would only ever go for a smaller size if I was using 3 monitors, then you could have 1 bigger in the middle and 2 same size beside it.
Thought your friend Ahmed helped you to buy a Samsung monitor, jamhassen?
On topic - I think you would regret the mismatch in screen sizes and possibly image quality and it would annoy you. Given the current price of the G2222HDL it would be quite a nice little setup.
