Hi,
I am programming in VB.NET
I want to move an IE window to the top left hand corner of the screen.
I have the following code, which works fine on my Vista PC.
Private Declare Function FindWindow Lib "user32.dll" Alias "FindWindowA" (ByVal lpClassName As String, ByVal lpWindowName As String) As Long
Declare Function MoveWindow Lib "user32.dll" Alias "MoveWindow" (ByVal hwnd As Long, ByVal x As Long, ByVal y As Long, ByVal nWidth As Long, ByVal nHeight As Long, ByVal bRepaint As Long) As Long
Public Sub positionWindow()
Dim smartWindowHandle As Long
smartWindowHandle = getWindowHandle(windowName) 'where the windowname is previously specified
MoveWindow(smartWindowHandle, 0, 0, 647, 550, 1)
End Sub
The window handle is attained using the following:
Private Function WindowHandle(ByVal sTitle As String) As Long
WindowHandle = FindWindow(vbNullString, sTitle)
End Function
and ...
Public Function getWindowHandle(ByVal windowName As String) As Long
Return (WindowHandle(windowName))
End Function
The problem is that on my Vista machine, it works fine. But on my XP machine, the window that is being moved, freezes and doesnt repaint itself. And when I run another window over it, it dissapears.
Can anybody offer any advice on how to move the window, without the window falling apart?
Thanks
End Sub
End Function
and ...
End Function
Thanks
