Stock, pricing, panel differences etc are turning me off this tft and i'm finding myself looking elsewhere as i want a solution soon and im not going to get it with the sammy.
The LG L226WTQ looked like a reasonable option but horror stories emerge from that option as well so i was thinking maybe going smaller 20" and going for a Dell.
The 2007WFP & 2007FP are appealing and in budget but the low contrast ratios and high response times are putting me off slightly.
Which direction do you think i should head with this? Look at a Dell option (which one as well) or keep on waiting for someone to sort out there stock, pricing and panel consistency with the Samsung?
Cheers.
Edit: Just seen the FP is 4:3, so that rules that out, but the WFP i've just seen for £215, sounds a bargain.
Cheers.
although out of stock
