Samsung green all the way. Where else will you get 2133 9-10-10-21-1T for £50?
This, also gonna be ditching my vengeance lp for the samsung. Mine needs 1.5700v to run at it's rated speed/timings. The fact it's low profile is the only thing it has going for it.Get the Sammy Green, it's really tiny and won't be an issue with large heat sinks.
The best thing is it's great for overclocking. Running mine at 2133 9-10-10-21 1T @ 1.46v. Amazing ram. Glad I ditched my Vengeance.
Okay sammy green it is, will probably wait until they have a offer since I'm not in a rush. Only got the vengeance cause they looked really good and since it was a good price at the time.
Has anyone noticed a difference going from 1600mhz ram to 2133mhz? I'm still debating whether to swap my corsair vengeance for some Sammy green.
But its no faster in actual use? Why would you "upgrade"?!![]()
You won't be disappointed, my Vengeance was the silly tall ones. I mainly bought it for it's size as I have a SA. I can now mount the front fan.
hope you all have a magnifying glass and tweezers when you sam green arrive![]()
