I'm struggling to get to grips with my 16gb sammy greens using an msi xpower II and a 3820.
Basically I can't get them to post above 1866mhz, which is fine for 24/7 but it's holding my benching back, would like to wrench as much as possible out of them.
Using the base and strap, 2000mhz won't post even with slack timings, same applies to 2133mhz on 100 base and 1.0 strap.
Loosened up to 11-11-11-32-2t 134trfc.
System agent is 1.2v, vtt is 1.05v, pll is 1.7v and dram voltage is 1.605v.
Any pointers as to where I'm going wrong??
