Sammy P2450 mount screws
27 Jun 2009
Hi guys
i have the above, and i have amount with a vesa 100 bracket to attach to the back of my monitor,
what screws do i need to attach it, cant believe Samsung dont supply the bloody things!!!
M4 (0.7mm pitch). Usually 10mm in length, but that depends on your bracket though.
Any luck? Post some pics :p
yes you would think ,, b and q would be in abundance of such things, plenty of M3 and M6 ones, could i find M4 screws, NO:mad:
im at work now and surrounded by monitors on stands:eek:
surely 3 screw on each is enough!!!!! ha ha ha
i do have 4 at home but they are too long and cannot asss around cutting them lol
