Samsung 20" Pebble - Stuck Pixel....Help!
23 Aug 2005
Cheadle, Cheshire
Hi all
I just received this gorgeous monitor last night and set it up only to discover a bright green pixel in the middle of the screen.
I have tried rubbing it and those pixel "remover" applications with no luck.
I did'nt purchase from overclockers, so can somebody tell me where i stand?
I believe that Samsung have a policy that if your product is purchased within 15 days of finding a defective pixel, then you can get a replacement.
Do i send it to where i bought it or do i send it back to Samsung?
Cheers :)
Samsung refuse to replace my monitor because i am in the UK. Their policy states anywhere in the world APART FROM THE UK!!!!
I will now send the item back to the etailer via the distance selling act and order a new one via overclockers. However i will not be ordering a SAMSUNG!
Cheers :)
I will send that back tomorrow via the distance selling act.
I have though in the meantime orded the OcUK Value 24" to be delivered tomorrow. BRING IT ON!
Have i made a better choice?
Cheers :)
