- 18 Feb 2007
- London
hi
ive got the sammy 205bw lcd monitor, ive not been able to use the driver software cd that came with it because it does not support vista64bit
ive connected it to my systems bfg8800gts card using the dvi connections
my question is do i need the driver for it?
it seems to be running ok without the driver, in the display options it says something like (default monitor on a 8800gts card)?
cheers
cheers
