- 26 Jan 2009
Good evening fellow monitor lovers, I require your help.
My Samsing 223BW is driving me nuts, I've not used it in a while, had it in the spare room collecting dust and today decided to rig it back up, so when I turned it on, it was ok, stayed on for 2 - 3 mons and went blank/black but with the power light still on, thought that it had somehow gone into standby but when I moved the mouse/KB the monitor didn't respond.
Turning the monitor off and on cured the problem but after 2- 3 mins it did the same again.
I've blown the DVi cable both ends for dust, swapping it around, swapping it over on the GPU outputs, tried in safe mode and in BIOS but issue still occurs.
Only thing I havn'y tried is a VGA cable as I don't have one to hand.
I've only moved the monitor it in its verticle position, steadily for about 12 yards.
GPU seems fine as I'm running my HDTV off it via a dongle now and have been for last 9 months.
If anyone can diagnose the problem or let me know if its repairable, It's out of warrenty so any suggestions please help.
