Just purchased a Samsung 226BW.
Im having a problem with using it with DVI. When I connected it with DVI there was a signal check box that told me to check the cables for analog. I then used the "source" button for it to change from analog to DVI and it then it has a blue and white box at top left that is changing between Analog and Digital, then when I assume it goes into digital mode it goes to standby (silver power button with flashing blue light).
Has anyone had a similar problem? is it the included DVI cable?
Currently Im using analog cable with dvi adaptor, would really like to get dvi mode working.
thanks
thanks
