SAMSUNG 32 HD READY LCD-TV LE32T51BX/XEU reviews?
30 Mar 2006
Essex
Hi all,
I'm about to purchase a SAMSUNG 32 HD READY LCD-TV LE32T51BX/XEU does any body own one or know any thing about them?
I will mainly be using it as a TV but some times will use it to surf the net or play fifa with mates, i know it has DVI connection same as my video card.
TV will be excellent, it is a sammy after all. I believe it will have both VGA (for PC) and an HDMI port for future HDTV products/computers etc.
Aye looks great to and its under £800 - can u believe it!
Only thing that will be a pain is my freeview i was looking for one with it built in but i don't think this has, but then I'm thinking i may buy DVD freeview all in one.
The 26 inch version I had which unfortunately broke and couldnt geta replacement... had a built in tuner.
Edit: Will email you some info, whats your address? (cant post on here)
[email protected]
ive coppied the below from another website,i cant see any thing about freeview...
whats Multi-channel Preview Picture-in-picture (PIP) ?
still catn belive i can pick this up for £750 :p
General
Weight 13 kg
Height 52.9 cm
Depth 10.4 cm
Width 91.45 cm
Product Type LCD TV - colour
Power
Power Consumption Operational 180 Watt
Power Consumption Stand by / Sleep 1.5 Watt
Voltage Required AC 220~240V
Power Device Power supply - internal
Connections
Connector Type 1 x RF input ¦ 2 x SCART ( 21 PIN SCART ) ¦ 1 x component video input ¦ 1 x composite video input ( RCA phono ) ¦ 1 x S-Video input ( 4 PIN mini-DIN ) ¦ 1 x VGA input ( 15 PIN HD D-Sub (HD-15) ) ¦ 1 x audio line-in ¦ 1 x audio line-out ¦ 1 x headphones
Audio System
Speaker(s) 2 x right/left channel speaker - built-in - 5 Watt
Output Power / Total 10 Watt
Speakers Included 2 speakers
Sound Output Mode Stereo
Remote Control
Type TM79
Television
Features On-screen menu, DNIe (Digital Natural Image engine), brightness sensor
Brightness 500 cd/m2
Viewing Angle (Vertical) 170 degrees
Viewing Angle 170 degrees
Image Contrast Ratio 2000:1
Image Aspect Ratio 16:9
Resolution 1366 x 768
Diagonal Size 32" - widescreen
PC Interface DVI, VGA (HD-15)
TV Type HDTV Ready
Technology TFT active matrix
Video Features
Teletext Memory 10 pages
Teletext Yes
HD Ready Yes
EDTV Ready Yes
TV Tuner
Stereo Reception System Nicam/A2 Stereo
My Sagem has this!... You press the button and it devides the screen up into 9 small windows automatically scrolling through the (5 Analogue) channels to show you whats on!... Mine also does PIP POP and PAP ( :D ) but not between Analogue and Freeview!...
Not that it matters as you have purchased but if its like its older brother there are two editions , one With and one without the freeview built in - model ending bdx has digital built in, and the bx's dont
