Samsung 850 Pro Ready for Pre-Order
22 Apr 2014
The new Samsung SSDs will be here shortly and you can pre-order your drive now with Overclockers. We will be getting the full range of 850 Pro SSDs with 3D NAND Flash. We hope to see stock land by the end of the month. I will keep you all up to date with the due date as that time gets nearer.
I will be adding more specs and speeds to the products as I get them from Samsung as well.
Samsung 128GB SSD 850 PRO SATA 6Gbps 3D NAND (MZ-7KE128BW) @ £92.99 inc VAT
The Samsung SSD 850 PRO delivers blazing-fast speeds with an exceptionally high endurance and provides the highest performance of SSDs with SATA III (6Gb / s) interface. The sequential read performance is achieved up to 550 megabytes per second (MB / s), the Write performance up to 520 MB / s The random read performance of up to 100,000 Input/Output- Operations per second (IOPS), the write speeds up to 90,000 IOPS.
Professional features for top performance
The Samsung SSD 850 PRO is not only for high performance, but also for a particularly long service life: With a daily workload of up to 40 GB, which 150 TB Total bytes written (TBW) corresponds to more than ten years, the new High-performance drives from Samsung and excellent for use in high-end PCs
Workstations based with high utilization.
These requirements comes Samsung with a Ten-year warranty for the SSD 850 PRO series after. In addition, the need Premium memory significantly less energy while increasing all performance Values??. If the "Device Sleep", the SSD 850 PRO requires just two milliwatts, which in Companies and wherever numerous PCs are durable in use, to a low power consumption contributes.
The drive also features the "Dynamic Thermal Guard "feature which ensures that the optimum temperature range and so prevents data loss due to overheating.
In addition, the drives support the Hardware encryption on Microsoft eDrive and TCG / Opal 2.0 with 256-bit AES, so Companies can control the SSDs in a network centrally.
Only £92.99 inc VAT.
ORDER NOW
Samsung 256GB SSD 850 PRO SATA 6Gbps 3D NAND (MZ-7KE256BW) @ £142.99 inc VAT
Only £142.99 inc VAT.
ORDER NOW
Samsung 512GB SSD 850 PRO SATA 6Gbps 3D NAND (MZ-7KE512BW) @ £282.98 inc VAT
Only £282.98 inc VAT.
ORDER NOW
Samsung 1TB SSD 850 PRO SATA 6Gbps 3D NAND (MZ-7KE1T0BW) @ £495.98 inc VAT
Only £495.98 inc VAT.
ORDER NOW
Got to ignore rapid enabled it caches the ram so cant be used to compare with other drives.
The result look good but tbh considering the price not sure youd notice much difference over say the mx100 at nearly half the cost if it was me id get 2 mx100 512s at 320 quid raid 0 them for massive speeds and 1tb storage and be happy id saved nearly 160 quid, and that coming from someone that has praised samsung and run 2 sammy ssds in my current rig
Just to add its not a dig at ocuk more a poor show samsung should have done better with these
Agreed. The MX100 really does make you compare every other drive against it on cost/performance.
Looking at the review of the new Samsung on Anandtech it's definitely the fastest, but as you pointed out would you really notice it in anything but a benchmark?
The price is silly on these. The Crucial MX100 is a much cheaper option at almost half the price. The only time you will notice the speed difference is when benching the drives.
Without a doubt the fastest SSD's out there and no doubt very reliable, but the Crucial MX100 has kind of spoiled their party a little giving such incredible value for money for such a high performance SSD. :)
The 512GB Pro looks very tempting :D
Will you also be getting the 850 with VNand TLC ?, I think it's going to be called the Evo maybe.
The Samsungs are built for Professional use remember not consumer like the MX100 so the pricing will be higher. They also have a higher TBW 150TB compared to 72TB and a better warranty of 10 years compared to 3 on the MX100's
I guess it all depends on what you want from the drive and how long you are going to be running them for and what you will be running on them.
I've worn a couple of SSDs for certain tasks so always consider durability, and these look good given twice the TBW of the 840 Pro and MX100.
10 year warranty is pretty darn good though!
Does anyone here seriously think we'll still be using these drives in 10 years?
Just bought a set of 840 250GB's for work to replace the old 120's, now I wish I would have hung on :p
There's always something new and shiny round the corner; with SSD at least the improvements are evolutionary rather than revolutionary (in terms of user experience).
