Samsung 930B
24 Aug 2005
I was thinking about getting a new tft monitor in particualr the samsung 930B
would be willing to spend upto £240 as its the price i have seen elsewhere.
primarily used for games and web/office, so if anyone has any better suggestions for price/performance please tell me as otherwise going to go through with this one. ta
Well, you could even consider the Samsung 930BF instead which is ~£240. It's an extension of the 8ms TN Film panel (from Samsung themselves) used in the 930B, but with the application of their overdrive technology, MagicSpeed. This has helped reduce grey to grey latency, and helps improve responsiveness in gaming. This might be a slightly better option if you're looking for a gaming screen and the overdrive control helps reduce the response time quite well. Worth a look for the price range...
iraiguana said:
thank you for the reply, did mean the 930BF and got it ordered now. really good information on your site has been really helpful. thanks again. :D
ah no problems, good choice and glad you found the site helpful too :)
