Samsung bf940
1 Jan 2006
Hello,
Just purchased a samsung 940bf,
Installed drivers for it, reinstalled gfx drivers
i am using dvi,
But i find the sharpness not up to scratch, as opposed to crappy pc world 16ms monitors im using at work, the text seems blurry and just not crisp. anyone else had this problem or know a way to solve?
Cheers
extremetoad said:
Hello,
i am using dvi,
Cheers
Mine does that if i have a low refresh rate, try putting it higher
I also orderd a Samsung SM940BF 19" on saturday, should be here in a few days
check you're running at 1280 x 1024 and 60Hz refresh rate. Also you might want to consider Cleartype. I've often found Samsung monitors look better with this enabled, where other models i prefer without
