** SAMSUNG CURVED MONITOR FOR UNDER £400 !! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Samsung have released a curved 27" VA monitor for under £400, check it out:-
Samsung S27D590C 27" Curved Widescreen LED Monitor - Black @ £389.99 inc VAT
Our new, 27-inch curved monitor takes movie watching and gaming to new heights, from the monitor's unique curved screen and comprehensive entertainment features, to the incredible picture quality and the impressive sleek design," said Phil Gaut, Director of Display, Samsung UK & Ireland. "The S27D590C further emphasises our focus to create a truly immersive and unforgettable entertainment experience.
The curvature of the S27D590C improves the viewing experience in comparison to traditional flat screen monitors, as the screen boasts nearly uniform viewing distances from the centre of the screen to its edges. This curve of the screen matches the natural curve of the human eye and makes it easy for viewers to completely immerse themselves in games and films.
Additionally, the screen's curve creates a wider field of view and greater sense of depth, which enables viewers to enjoy a panoramic experience and gives the screen a 3D-like effect. The 3D effect is particularly apparent when enjoying games, such as racing and flight simulators, avatar-based adventures and shooting games.
With an ultra-wide viewing angle of 178 degrees, both horizontally and vertically, the curved monitor's vertical alignment (VA) panel optimises the viewing experience from any position and minimises picture distortion. In addition, the S27D590C's Mega Dynamic Contrast Ratio technology delivers a high contrast ratio of 3000:1 and 350 cd/m2 brightness help produce life-like images with deeper blacks, pristine whites and brighter colours.
The integration of enhanced entertainment features takes gaming and multimedia content experiences to the next level. The monitor comes fully equipped with built-in 5-watt dual speakers that deliver high-quality stereo sound as well as a game mode function that can be quickly activated with a simple touch of a button. The game mode intelligently detects on-screen changes and corrects blurry images, enhances colours and alters contrast for improved visibility of in-game action.
The monitor has a minimalist design, ensuring viewers enjoy the enhanced viewing experience of the curved screen without any distraction. Users can also easily adjust the screen angle using the tilt screen function to minimise glare and reflection. The monitor also supports 100x100 mm VESA standard brackets for stress-free wall or table mounting.
Specification:-
- Screen Size: 27"
- Panel Type: VA
- Backlight: LED
- Brightness: 350cd/m
- Dynamic Contrast Ratio: 10,000,000:1
- Static Contrast Ratio: 3000:1
- Resolution: 1920x1080
- Pixel Pitch (HxV): 0.2331mmx0.2331mm
- Response Time: 4ms
- Viewing Angles: 178/178
- Colour Support: 16.7M
- Connectivity: DisplayPort, HDMI, Analogue
- Speakers: Yes (2x5W)
- Stand Type: Tilt
- Warranty: 2yr
Only £389.99 inc VAT.
ORDER NOW
works fine here. just not sure 400 is the right price and 1080p the right resolution for 27" VA panel.
It seems curved adds a £100 minimum premium and more, a 1440P would be nicer.
But for me curved should really be on 34" and larger, I'd love to see a 38" curved desktop monitor with 3440x1440 resolution, think it would be epic, especially for gaming and movies. Even better if they could somehow make a 144Hz version and IPS, would not like the price though, would be 4 figures easily. :eek:
Is 27" not a bit small for a curved screen? I thought this was aimed at 55" and even bigger tv's. I certainly can't see any difference in the picture towards the edges of my 27.5" HannsG.
Yeah seems a little small for a curved screen. For a monitor that's curved I would've thought 32 inch minimum. Plus only 1080 is a bit disappointing at that price, really needs to be 1440/1600 minimum.
LG have got it right with the curved 34" 21:9 monitor. That works much better because you sit close to an 83cm wide monitor. 27" doesn't really need to be curved as it fits the field of vision nicely.
Even the 60" TVs don't need to be curved at 16:9, because you sit so far away from them. Only 21:9 aspect ratio need to be curved if you sit close enough, to fill the peripheral vision and not distort due to the natural curvature of the eyeball.
I really really fancy the curved LG monitor as a second monitor for a dedicated driving / sim setup but I'm worried I'll miss the g-sync and high refresh of my Asus SWIFT when using it... :confused: I've already noticed I don't like gaming on my TV as much as I did before the SWIFT arrived.
I though IPS has better colours and wider view range? VA because it has better responding time?
Viewing angle doesn't matter as much for monitors, and whilst colour accuracy is better on IPS, you sacrifice black levels, which I personally think are more important in games.
Definitely agree. Immersion with a curved monitor requires a larger screen. I'm not even bothered about 144Hz because the games that will benefit most from this kind of set up on 1 or ideally 3 screens would be driving or flight situations.
