Samsung D600 converting video
20 Oct 2002
Bromley
whats the best program to use for converting video to the 3gp formatthe phone uses and what settings should i use. I have a 512mb card?
There is a good bit of software made by eRightSoft called Super3gp converter. It's a freeby and quite good . It's a player[viewer] and a converter rolled into one and will convert most formats to and from 3gp.
I tried it to convert a 3gp vid to an .avi and although the quality was OK there was no sound . It may have been a setting out or a missing codec , but still ,the program's worth a try.
The settings you want to use depends on your screen size, just select a bitrate that makes you happy with the quality.
