Samsung e530 default pin
Permabanned
26 Oct 2002
Sarah has a Samsung E530 and I tried to install the wap settings but it asks for the pin. Alas Sarah doesn't know, what is the default or how do you change it ?? :confused:
typically all sammy handsets use 8 zero's, or 00000000, as the default pin.
hope this helps.
