samsung galaxy s 8GB memory distribution
27 Nov 2010
Is it true that only 2GB are for Apps and 6GB for OS and music, photos and videos?
Also can you install apps on the SD card?
1 - Yes, although I have the 16GB I assume it makes no difference.
2 - They can be installed to the 2GB allocated memory or the remainder of the internal memory.
So i can use all of the 8GB for apps and not just media? and i can put apps on SD card?
You can put Apps on all of the internal memory(the 8GB it comes with). I dont think you can put any apps on the external SD card(any extra SD cards you add). I doubt anyone can get 8gb of apps thou.
