- 30 Dec 2009
- Wigan Lancs
Is this still available?? I want some more but can't find any.
Why did they discontinue this fantastic ram
Tbh if you're running it at 1866 you're wasting it anyway. 2133 9 10 10 21 ftw
Yep, 9-10-10-21 1T cmnd rate is the sweet spot with the greens.
Ooooo, I might try this!
What sort of volts will it need?
Also, can you do 2133 on X79?
So if I wanted to go to 2133MHz, what would be 'safe' timings considering I'm on X79 and running 4 x 4GB in Quad Channel?
I'm thinking I'm best getting to 2133MHz with loose timings then trying to tighten them, rather than going straight to 2133MHz with tight timings and then lossening them until it works.
So what are reasonable loose timings to start with? (e.g. Don't wanna start at CAS13 unless I have to)
On X79 theres very little reason (unless your doing something specific) to run anything other than 2133MHz 9-10-10-21-1t (sub timings don't make much odds) that gives the best overall balanced performance and anything else will be so small gains really not worth it. With a bit of luck you should be able to go straight in at that.
Exceptions being stuff like if your mostly using high end multi GPU for rendering or compute or running more than a 6 core CPU where you can get some advantages from silly high MHz RAM or if your doing a lot of certain CPU compute tasks which favor tighter timings over anything else.
