I have a R730 that has gotten slow, so I thought an upgrade was in order, so I've bought some new/more ram and stuck in a M4 SSD.
Going to install windows from DVD and it goes through the loading files bit but then just cycles through that over and over. If I eject the disc it just says no OS found.
what you reckon, any settings I need to adjust in bios?
Cheers
Cheers
