SAMSUNG LC43J89 -- wall mount
24 Apr 2008
South-West
Hi All,
I have had this monitor for nearly a year now, and am now tempted to mount it to my wall. I believe it takes 100x100mm vesa mount. Just wanted to know if anyone had any experience in doing this and if there is a particular mount i should be looking at? I don't have a budget, happy to spend as much as necessary for a good job. Thanks.
Loads on the Rainforest... just look at reviews and the weight capacity. Duronic are a good brand, I've used a few of their's over the years, but there are many others to choose from. Not sure if you want a fixed mount or an arm, but there is something to suit regardless.
