Mine worked perfect with the code given in the samsung manual!
If your s doesn't work then it's 99% because you are using a fairly old sky remote! If you get a new sky remote it should work fine! I think anything from a rev 6 upwards!
Rev6 is the remote no. You can find this no by removing the battery flap on the remote and it'll tell you inside!
