- 1 Mar 2008
- Near Longleat, Raaaar!!
Hi All, I recently bought a samsung lu28h750uquxen and so far, I'm loving it!
However, I have a problem with Freesync running either in standard or ultimate mode in Fullscreen gaming on BFV. I know there are issues with Freesync on non certified G-Sync monitors but every so often when I boot up BF5, it just runs perfectly.
Most of the time, with Freesync set to either standard or Ultimate, I either get a stuttering unpayable mess (and before anyone says 'that's just BFV!!' I know it isn't the game
or if I use ultimate, I get the signal dropping out to blackscreen every second or so.
With Freesync set to off on the monitor itself, the issues go away, but I get tearing
Weirdly, in Borderless it seems to work fine, but I understand that I am losing FPS that way.
I'm using a 1070 so the Framerate is either 60fps (lowish settings
) or drops down to 45+ and when it works, which isn't very often, it looks amazing. Every bit the experience I was hoping for from Freesync.
From LOTS of googlefu, it would appear that the usual freesync issues, flashing etc aren't what I am getting. Is it likely to be a fault with the monitor itself?
I messaged the firm where I bought it (sadly not OcUK) and they said that they would offer me a refund, no quibbles, but if this is a known issue by you knowledgeable people on the forum, changing monitors won't help I guess.
I have tested all the other parts of my system as recently upgraded CPU mobo etc so confident its either a known issue with running g sync on a freesync monitor, or an issue with the monitor itself. Advice much, much appreciated
Spec if you need it:
1600 at stock
Asus Strix 1070 OC
16gb 3000
SSD for boot and games
or if I use ultimate, I get the signal dropping out to blackscreen every second or so. With Freesync set to off on the monitor itself, the issues go away, but I get tearing
Weirdly, in Borderless it seems to work fine, but I understand that I am losing FPS that way. I'm using a 1070 so the Framerate is either 60fps (lowish settings
) or drops down to 45+ and when it works, which isn't very often, it looks amazing. Every bit the experience I was hoping for from Freesync. From LOTS of googlefu, it would appear that the usual freesync issues, flashing etc aren't what I am getting. Is it likely to be a fault with the monitor itself?
1600 at stock
Asus Strix 1070 OC
16gb 3000
he also couldn't tell me the freesync range of it, seems a bit odd as it isn't listed anywhere I can find.
