Samsung NC10 Cases
13 Jun 2008
Hey. So, I bought this NC10 off a friend on the cheap, as the condition of the case is pretty bad. Does anyone know of a place that sells the original NC10 cases, if so how easy/hard are they to fit?
Cheers.
you could try from samsung website. to swap or replace the case is easy as long as you be careful and know what you are doing.
