Samsung NC10 Issue
8 Mar 2007
Poole, Dorset.
Well it all started last night!!
I have windows xp installed with a C and D drive partitioned equaly using the samsung software when first turned it on.
Ive been using the nc10 for about 6 months with no issues at all.
I turned the nc10 on and i wanted to access the D drive to watch some movies, which are installed on the D drive, but when i double clicked the drive nothing but this option happened:
The Disk in Drive D is not Formatted, Do you want to format now?
So I try Quick Format and normal format and always says "windows cannot format this drive"
So I then tried the F4 option while booting up to restore to factory settings, but it only works for the C Drive, so I still can`t access the D drive.
The D Drive is nearly full with about 70gig of pics and movies.
I am now at a loss of what to do!!!
Thanks
Checked in Disk management to see if the drive is enabled? Had that happen randomly to me once
EDIT: scratch that, you wouldn't see the drive if its wasn't enabled which was the issue i had
Thanks mate...some weired stuff is happening here.
The D drive has changed from NTFS to RAW
I`ve typed in run CMD for command prompt and typed Convert D: /fs:ntfs
and I received: convert is not available for raw drives
