Samsung NC10 replacement casing
28 Mar 2005
Is it possible to get a new case for my NC10. i have a white one but dropped it not long ago, and have cracked the casing around the screen!
just looking online and when i google it i get results for a carry case :(
I had the same issue on mine the LCD Bezel cracked at the corners, even though it wasnt abused, I had it replaced under warranty and you should be able to as well.
