Samsung P2370
21 Jun 2010
infornt of my PC
Well it finally arrived. After an impulse buy on a special.
I can't believe how sharp it is compared to my 19" WS.
Running the desktop at 1920x1080 is a big improvement over my old 1440x900.
Only slight negatives is that there is no vesa mount and it tilts forward a little.
Will have to put something under the stand or a little duct tape at the back to pull the monitor back a few degrees.
Those are minor points anyway and for the price £119 you can't really complain.
Leaves me £££ in my pocket to get a new gpu now.
So it does, I didn't want to force it.
Well this makes it even better.
After a few days of putting the screen through its paces, I am over the moon.
Viewing angles are good, colours appear solid across the screen and as mentioned with the extra few pounds I have saved, I now bought a gtx 480 from OC.
Also just want to add that I can not fault the service.
