Samsung R70 & getting 1gig Turbo memory to work
22 Oct 2003
UK, Brighton
Hi all just purchased a 1gig Turbo memory module, for Samsung R70 but i cannot see anything in the bios to enable this feature? as it will not boot into vista with it fitted.
but i did notice enable Turbo memory in a previous bios.
(running bios 06AB at the moment) i cannot reload the older bios?
any suggestions lads?
i have had this suggested, but have tried but i cannot get it to work:
"To downgrade the BIOS, you have to use the CD version of the BIOS updater, and to force the downgrade you have to enter the name of the BIOS file followed by:
/s /x /c /nomodel_partcheck"
tried the above but cannot get it to flash (the older bios is 04ab) what am i missing? the disc boots into dos and i type '04ab/s/x/c/nomodel_partcheck' then i get an index of commands??? :confused:
Spec in sig
thanks all
Ninja :)
