Hello,
Having had a right google around this, this is a common error with any icore laptop supporting the 540m chipset, I mean literally hundred of threads.
Anyway pick of a bunch:
Dual boot here:
http://www.sevenforums.com/tutorials/8057-dual-boot-installation-windows-7-xp.html
Possible xp driver:*http://forums.laptopvideo2go.com/topic/29285-v29610-windows-xp-32bit-nvidia/
A place for alternative nvidia drivers:
http://www.laptopvideo2go.com/
a lot of people/ posts reference this guy:
http://blog.komeil.com/2010/04/nvidia-driver-windows-7-notebook-laptop.html
Nvidia modding tool:
hardwareheaven.com/nvmodtool.php
Possible other solutions:
http://www.commandandconquer.com/fo...974-Windows-7-64Bit-Solved-I-REPEAT-SOLVEDDDD
Or
Hi, I have XPS L701X win 7 64 bit with nvidia GeForce GT445M. I have set compatibility to vista (service pack2) and run in admin. In nvidia control panel go to display, adjust desktop size and position, then select use nvidia scaling with fixed-aspect ratio.
Or
I also have an Acer Aspire 5742G with a GT540M. I fixed it by complete accident when I was altering the drivers and config files to get F1 2011 running smoothly. I did so by installing the new Intel HD drivers first, found here (get the 32 bit if you need to).
I then downloaded Nvidia drivers 280.26. The installation indicated that it didn't install correctly. However I rebooted, and then my laptop rebooted a second time. After that I fired ahead and added my games on the Nvidia control panel. Runs absolutely perfectly, getting more than 30% FPS increase over the previous setup that was already preinstalled on the laptop.
Hope that helps for anyone with optimus issues*
Thoose drivers here :*http://downloads.guru3d.com/download.php?det=2789
J
Dual boot here:
Or
Or
J
