Hello people,
As per the title my girlfriends Laptop (Samsung RV520 i3 2330m spec) is having problems and typically is about 2 weeks outside of its warranty
Basically this is what happend.
Sunday night i was on the laptop and the battery got low and i was lazy so just used it until it turned itself off.
Yesterday the girfriend goes on the laptop with the charger plugged in it boots up fine and resumes from where it shut itself down.
After about 2 hours or her looking at shoes and other typical girl stuff on the net and facebook it bluescreened, i also noticed it failed to do a system dump and was stuck on this blue screen for about 20 mins.
So decided to hold the power button to turn off and then turned back on and since then it turns on straight to the boot options screen with f2 for boot options f4 for recovery.
What ever I try I cannot get past this screen and there is no noise from the laptop at all.
Any idea what has happend or how to fix? I have a recovery disc but nothing is happening.
Can i remove the HDD and plug it into my desktop to get the photos off that the GF is upset about loosing?
Please help.
Many thanks
Please help.
Many thanks
does anybody have any idea?
