samsung S23B550V buzz
25 Aug 2012
Hi
I have just bought one of these LED monitors which has integrated speakers. It is set up as an extended screen for a laptop. The speakers work OK but as soon as a sound cable is plugged into the "in jack" of the monitor a constant buzzing noise, not very loud but noticeable enough, starts happening (for that to occur, the other side of sound cable is not even connected to the laptop).
Is this normal with this sort of monitors or is it something that should not occur at all. It is actually bothering me because the monitor is new (wondering if I should return it) and I tend to unplug the sound lead when I am not listening to anything in order to avoid the constant buzz.
Cheers
