Hi guys,
Finally decided to upgrade my first gen Hazro 24" to dwell in the 120Hz world.
Unfortunately my 2x 460's in SLI only have mini HDMI and DVI-D outputs.
I've hooked the monitor up HDMI to mini-HDMI and HDMI to DVI-D (with a HDMI cable and suitable adaptors) and it works fine but only at 60Hz. As I understand from some forum search this monitor only outputs 120Hz via Displayport.
I bought a Displayport to HDMI adaptor and also a Displayport to DVI-D cable and hooked these up but neither of these work. Interestingly the monitor does detect some sort of a signal since it goes black screen where as if I unplug it it says no signal. Any ideas?
I'm just understanding that there are active and passive adapters and wondering if this has anything to do with it. I pressume the cable/adaptor I've tried so far are passive (not sure on the adapter front though).
I've hooked the monitor up with the included Displayport cable to my laptop with a Displayport output and it works fine at 120Hz.
Any help greatly appreciated.
PS: Super impressed with the monitor's image quality coming from a good and calibrated IPS panel.
