samsung s90c oled
1 Jun 2014
dose anyone have a samsung s90c oled TV and using it for gaming with AMD GPU ? Just want to know if it will work without any problems with a RX 7900 XTX
I have a s90c , I use it for gaming (Xbox) but I have never hooked it up to my graphics card, I can’t imagine it being a problem?
What do you think of the tv? I’m planning to buy one soon, it was that or the LG C3 but rtings thinks the Samsung has the edge.
I own the S90C but modded it, to be an S95C in terms of brightness and turned off the auto dimming, to do the same just make sure it's a gen 2 panel :)
it's well worth the money if you want amazing hdr performance in movies and games.
It'll be fine for any high end gpu provided you use hdmi :)
Interesting thanks, how did you mod it?
Well the caveat is people say it breaks your warranty, but you just got into the service menu and there's a specific panel type
With a service remote I accessed the service menu.
Under Option & TypeI had a 55A40UGOC (S95C panel)
which means it is compatible to be changed into an S95C.
Other model codes are likely S95B panels.
I changed this to 55A4OUSOC (S95C code)
I backed out and then turned the TV off for 10 seconds.
I turned it back on.
Brightness goes from I believe 200/1100/1100 to 280/1400/1400
you can also turn off auto back light dimming and some other stuff, but at your own risk :)
If anyone is after one,
Do the following
S90C
Trade in any tv
code TV10
and topcashback 20%
got a 2nd S90C for £809 which is £648 (Including waiting for the cashback which was £161 and takes 8 weeks)
