Hey all,
So i ordered a Samsung Sa300b
at the beginning of the week from Amazon and when it arrived i had been sent a TA300 hdtv
. I can't order a new sa300b for now as it was the last one i was meant to have received so it is listed as out of stock. It was a referb on Amazon as my budget after buying a case is around £100.
I decided to probably look around for another monitor before i contact the sellers as they may have sent the wrong one (both where referbs, listed as 1 in stock) but may have just messed up the Amazon listing and the TV is worth double what i payed for the monitor. I need a new TV anyhow and don't want to end up having to pay the rest/send it back and not get the originally ordered monitor.
I found the Sb300h -
And can't really find any differences, though all the different Samsung urls have different layouts for tech info and Amazon has different sellers thus different layouts and amounts of spec info also any pictures i find for either when i search show it only as VGI compatible; the same picture over and over, might not even be the right monitor. I have deducted for searches the SB300 is VGI and HDMI compatible so there wrong.
Has anyone owned/currently does own one of these and can give me any info. All the reviews i have read are good mostly but if the originally ordered item is much better ill wait see if it is added back to stock before ordering the other (Would i be correct in assuming the SB300 may be newer as logically the would make the A series, then B and so on ??)
Thanx in advance for any help !
. I can't order a new sa300b for now as it was the last one i was meant to have received so it is listed as out of stock. It was a referb on Amazon as my budget after buying a case is around £100.I decided to probably look around for another monitor before i contact the sellers as they may have sent the wrong one (both where referbs, listed as 1 in stock) but may have just messed up the Amazon listing and the TV is worth double what i payed for the monitor. I need a new TV anyhow and don't want to end up having to pay the rest/send it back and not get the originally ordered monitor.
