Samsung SM-2032MW Pebble
31 Aug 2004
Midlands
Hi, really desperate for some advice on LCD monitors.
I need a new monitor for the bedroom and Im thinking about getting the Samsung SM-2032MW Pebble. It will be mainly for general computer use, watchin dvds and for use with sky tv. Connecting sky through the SCART socket. Would this work out ok? Would there be any problems with resolution?
And also does this model come with a remote control? It does not say so on OCUK but with a competitor it says it does have one. :confused:
Any help appreciated.
It's a PC monitor not a TV, it has no remote or scart sockets (if that's what you meant?!) and i have the 22 inch version and prefere my 20 inch ViewSonic display for watching DVD'd etc.
The samsung is a lot brightly and gives much better colours in games though i find.
The MW has scart and an analogue tuner among other types of connection. Its the BW version that does not.I see no reason why sky wouldn't work fine over scart,it may scretch to fill the frame but thats going to happen with most tv/monitor combos of this size I would guess.
