Samsung SyncMaster S27A850D
I think you need to be more specific. It's a 27" 60Hz PLS monitor. You CAN use it for gaming like any other monitor. Granted, it's old (2011), not 144Hz, and it doesn't have FreeSync or G-Sync, so there are naturally better monitors available, as well.
The most probable obstacle would be the input lag (~28ms). Which prevents proper competitive twitch gaming. But like you said, you're not a massive gamer. All in all, it should be fine for your needs.
If you want a more detailed analysis, try this:
http://www.tftcentral.co.uk/reviews/samsung_s27a850d.htm
Thanks.
