Samsung SyncMaster SA350H 22
IC3
IC3
3 Dec 2011
Hi every one i want to sell this monitor and get LCD.
Iam not happy with TN as i think it not that great.
The question is what monitor whould you say for 150 pounds should i get for gaming ?
I mostly play FPS: COD,BF,CS and DIRT 3
I think £150 pounds is a bit of a squeeze as it puts the Dell u2312hm out of reach.
The Iiyama ProLite X2377HDS features an IPS-panel and is within your budget however. OC UK currently has the monitor on its weekly sale btw.
Thats not a problem but what do you think of the size.
You see my desk is long but in width is not that big :mad:
what about http://www.overclockers.co.uk/showproduct.php?prodid=MO-000-IM&groupid=17&catid=948&subcat= ???
Or do you think its too small ?
My width of desk is 60cm
Iam about 76-79cm away from monitor, and i play lots of fps, most time i spend on CS 1.6 5vs5
Oh and it doesnt have to be IPS. But for sure i hate LED screens...
I think you need to figure out what you want want before purchasing anything.
The SA350H is an LCD.
I am not happy with TN as i think it not that great.
If you don't want a TN-panel you're left with either some VA or IPS variant. TN and IPS monitors are both available with CCFL and LED backlight, not to mention LED backlighted monitors don't really have any major disadvantages besides a more limited color gamut (and even that isn't necessarily true.. not to mention considering your budget something that's completely irrelevant).
All in all, I think you're confusing a lot of things and would be better off describing what it is you don't like about the current monitor.
I have a feeling he might not have set it up properly. Having used larger members of the SA350 series I know the image is fairly lackluster out of the box but amongst the best you'll get for the price once tweaked. Oh and you won't find anything more responsive for the price, either. If your complaints have nothing to do with viewing angle, OP, let me know your GPU and we'll see if you can set things up better.
The thing is that it makes me tierd after 2 hours of playing or just borwsing web.
And it hurts my eyes more then Normal LCD.
I dont know why is this.
In my opinion if LED screen is not set to 100% then it doesnt look good and your health is at risk. Its just my opinion.
So from the monitor i want small input lag, response time, size 20 inch.
22 its just too big...
