Samsung T220, flicker issue....
3 Apr 2007
London
Hi, had one of these for about a week now and it flickers terribly when gaming. Some games worse than others but in BF2, which I play a lot, it is horrible.
It's almost like it keeps adjusting the brightness or if it had a backlight on a different refresh to the image but once you see it it bugs you all the time. You can even see it do it when loading into a server on BF2 as the progress bar goes up, as soon as it is loaded and ready to connect it goes mental.
Sometimes it's like the brightness is pulsing other times it's like scan lines with waves of it going up or down the screen.
I've contacted OcUK who are going to get it picked up on Monday but wanted to know if anyone has one of these monitors, is it a know issue with them, is it a know problem with higher res or w/s monitors in general? My old 19" 1280x1024 was fine.
I'm just hoping they find a fault and I get a decent replacement as other than that the monitor is fantastic. Or whether to just try for a refund and a different monitor?
Main reason I went for this one is it matches my Series 6 TV.
I've been through all the options on the monitor, ATi CCC, tried different cables and connections on the card. None of which seems to help.
