Samsung t260HD?
6 Jul 2008
Hi all.
Now that Ocuk have the Samsung T260HD in stock now im tempted to get in my car and drive the 70 miles to pick one up. Before i do has anyone got one of these? i will use it for gaming and tv use and hopefully to watch blue ray.
So if you've got one what are your thoughts, other than this its a 32inch 1080p lcdtv and ive been told they are not that good with games, so thx for any advice folks:)
Hi there
The Samsung T260HD has a few advantages over a normal 32" HD Ready TV.
First one is the fact the Samsung T260HD is True/Full HD as it can support resolutions upto 1920x1200 which means True HD is supported.
So when it comes to using on a PC makes it as good as any 24"-28" LCD Monitor.
The TV Tuner is a digital and built in and is the same tuner found in the Samsung televisions which is very good.
The only downside to this monitor is the fact it uses a TN Panel which limits viewing angles a little, horizontal viewing angles are very good, but vertical are a little poor but if your looking head on or slightly from the sides the picture remains fine. The monitor has fantastic colours and the image quality from head on is spot on.
Thanks Gibbo looks like it will fill most of my needs, i just hope it has not to bad input lag and bluring as i like to play cod4 and other fps games, again thanks for the reply looks like it will be worth the journey down to Stoke :D
