Samsung TabPro Wireless oddity?
9 Jan 2003
Cornwall
Not sure if anyone else has had this
I picked up a 10'' tab pro for the GFs birthday, it's quite nice but every few mins the wireless seems to reconnect.
All other devices on the network are fine, had anyone else had a similar issue with other samsung tablets etc?
Same tablet, same issue on bt home hub 3, set a static ip on the tablet, then change your hub's settings to a static wifi channel Rather than automatic.
Only bugger is you have to change the wifi channel periodically to get any decent speeds (about 3mb down 10 up before, 45 down 15 up after which is our line speed).
According to the rather scarce pickings on the internet its simply a home hub issue and a decent router shouldnt have the problem Although if anyone can shed more light on that i welcome it. mine doesnt seem to have any issues on our uni's wifi (and i presume theyre using decent kit) which agrees with that.
