Because it could feasibly be 2-3+ months now before he can visit with it (ferry from Northern Ireland and the Scotland route being off bounds). And you had mentioned I'd possibly be able to offload it without too much loss.
But yes, at that price it is just a waste of money for me, so I will just wait.
BIB - I think you've got your wires a bit crossed there. I mentioned the idea of offloading a
second-hand soundbar without too much loss. You're talking about a
new soundbar; or at least I presume you are when you mention a 10% NHS discount on Samsung gear. That sort of thing won't apply to something second-hand.
At this point I suppose I should ask whether you understand that the abbreviation 's/h' stands for second-hand; and that second-hand is different from new.
Second-hand gear has already gone through the initial depreciation phase. That's why it's possible to sell on for a minimal loss so long as you didn't overpay.
For second-hand (s/h) sound bars that are good for music too I'd have a look at the following
- Q Acoustics Media 4 (M4) and the later Media 3 (M3).... Fairly recent products. Simple stereo configuration. No HDMI but has Optical input. Two 6" concealed woofers, so deep bass for a sound bar. The M4 dates from 2016/17 I think. New prices around £300. S/h prices from £80 to £140 for the M4 depending on condition and accessories.
- Yamaha YSP-series sound bars. YSP-600 is much older than the Q Acoustics gear (2008 IIRC), but sonically superior in all except the deeper bass of the M4 and M3. It was £600 new. Very effective virtual surround in a sympathetic room. Good for music for a sound bar without external sub. Basic HDMI ins and outs: 1080p, HDMI Control, but predates ARC feature. Used prices very volatile though. Lows of £60 to highs of £150
- Yam YSP-500 - as above for sound. No HDMI but plenty of digital and analogue inputs. Silver colour is a bit out of fashion now.
- YSP30D and 40D - HDMI and DAB tuner.
Older units such as YSP-1, YSP1000, YSP800 are coming on to Ebay for daft money. They still sound good, but IMO they're over-priced for the age.
I'm pretty sure most of these come with a subwoofer output socket, so if you have a spare sub then that could be hooked up for fatter bass. The set-up mic and remote are important accessories. Don't buy a YSP-series sound bar without them.
Thinking about ways to get the Aegos connected at minimal cost and without getting involved with circuit board builds, a cheap remote controlled preamp such as the PGA2310 for around £50 would be a start (search on Ebay). Then add an Optical to analogue stereo convertor will take care of changing the digital Optical audio in to a stereo signal for the pre-amp. These convertors start from under £7 + delivery.
*** While you're on Ebay, look up item number 163836129352. This is a
small Optical to stereo analogue convertor with an IR volume control. It's under £13. I have only just found it, and I have no idea whether it sounds any good, works okay, or is reliable, but for the price I think it may be worth a punt even if it only lasts until your friend can visit.
