Samsung Ue32D5520 reboot problem
14 Dec 2004
South
Hi all, Just put my ue32d5520rk in my daughters room, after running an aerial cable in. Plugged all in, re-tuned and all ok. Then it rebooted, then kept doing this.
Reading up online, I tried holding 'exit' for 15 seconds, but that did nothing.
I read to press MUTE 2,5,8 EXIT. This appears to stop it rebooting, but doesn't say its updating software, like it should with that button combination. But the TV wont do anything. Even the buttons on the tv wont change channel, but the LED flicks to say its noticed and input. But the fact the TV stays on rules out the power board to me and points at the logic board.
Then I read to take the back off the TV, link out the eeprom, reset to SDA. Power on and wait 20seconds, then power off. Power back on once link wire removed and its reset. Nope, not for me.
I checked the ribbon cable and cannot see any signs of overheating.
Any ideas on what else it can be, other than buying bits, with doesnt seem cost effective on an old set.
leave tv into standby then press in quick succession info menu mute then power and try a full factory reset, if that doesn't work id say main boards goosed such is with the D5520 if the terrible screen ribbon bonding didnt get you the crappy mainboards did
I had the same rebooting issue on a UE40D5220 - the mainboard was at fault. I sent it for repair to a place called GTV in Watford. He swapped a chip on the mainboard, updated to latest firmware and sent it back. TV has been perfect since then. Cost was around £70 including return delivery.
Edit: I did do all the ribbon cable checks too.
Hi
Did you have any luck with your TV , I'm having a same problem since I tried to connect to internet.
