- 13 Aug 2006
Hi all
I'm looking to upgrade my monitor and considering ultra wide. I will mainly be using it for work and casual gaming. I get discounts on Samsung products through work and so mainly focused on the following monitors
C34J79 - 34"
https://www.samsung.com/uk/monitors/curved-c34j79/#benefits
CJ890 - 43"
https://www.samsung.com/uk/monitors/curved-cj890/#benefits
Each have their pros and cons but I'm interested in views regarding the size of the overall screen and whether 43" would be overkill? One of the benefits of the CJ890 is built in KVM switch which would be valuable to me as I can hook up both my personal pc and work laptop at the same time and multi task.
On the flips side, the CJ890 is 3480 x 1200 vs 3,440 x 1,440 on the C34J79 so will I be compromising on the quality of the display in terms of pixilation if I went for the bigger screen?
In terms of gaming the 43" is 120 Hz, 5ms response time but no support for variable sync vs the 34" is 100 Hz, 4ms and AMD Freesync.
My biggest consideration is the overall size and the practicality of spending hours in front of a 43" ultrawide. Would be good to hear from folks using 43" plus, especially in terms of sustainability (spending hours in front of the screen) and ideal viewing distance (viewing distance will be about 60 - 65cm for me).
Any thoughts would be much appreciated, I am also open to other alternatives under £650 (which is my max budget).
Thanks
C34J79 - 34"
CJ890 - 43"
Thanks
