Samurize : gfx card temp meter ?
5 Jan 2005
Engerland :)
I have Samurize running... various temps and meters are running.... is it possible to display the temperature of my GFX card ?
couldnt see a meter already.. .unless I missed it :eek:
well i know samurize has speedfan and mbm modules built in. if either of those can display your gfx temps, then it's just a question of editing your config to suit. if you're using something else to get temps then you'll need a 3rd party plugin. try asking over at the samurize forums? :)
ATI Tool has a setting under 'Temperature Monitoring' to send the GPU and Environment temps to sensors in MBM, which you should be able to add to a Samurize config.
cool - just found that.... will have a go at that.... just found that maybe rivatuner will do it to ?
thanks fellas.
EDIT :
thanks fellas - used ATI tool > MBM > samurize ... great utility - now for the fans :D
