- 1 Sep 2005
- Scottish Highlands
Im currently working on a new samurize config. If you look at the picture above, you can see that Ive replaced the system clock area of the system tray with a samurize config. Next to that I have a toolbar of 'my computer'. Now the problem im having, is that I use that toolbar all the time, and im used to it being right over on the left hand side, but as this samurize config is getting longer its getting pushed further to the left. Does anyone know if there is a plugin for Samurize that will do the same thing? Or is there any way I can switch the positions of the toolbar and the config? Also are there any decent, highly customisable samurize clock scripts to replace the system clock?
