Hi guys. I want to start preparing a door and the door frame today before painting. Can anyone recommend a relatively inexpensive sanding machine I can pop out and buy, possibly from Toolstation? It's not a flat door so I've no idea what machine would be best for it. I mean I can certainly do some hand sanding for nooks and crannies if I need to. Door frame is also not flat. And I also need to sand the wooden step.
This is the sandpaper I have, 80 grit and 240 grit. Are they suitable for the job and for a sanding machine or do I need another grit? I also have a rubber sanding mould. I don't think I need to remove the paint completely? I guess just enough for a key and then primer.
I also better get a decent mask. Is this one good enough?
www.toolstation.com
Maverick FFP3 Moulded Valved Disposable Face Mask
• Ergonomic face mask designed to provide the perfect fit for optimum comfort and an airtight seal.• EN149:2001+A1:2009 FFP3• Protection against non-toxic solid and liquid aerosols• Adjustable nose clip prevents glasses or eyewear from steaming up• Easy-flow exhalation valve for lower breathing...
